TwinTurbo.NET: Nissan 300ZX forum - i cleaned the outside not the inside.
DE944
on August 08, 2011 at 10:02 AM
Interesting, I'm going to recover the system tomorrow.
posted by Draker (Eugene, OR)
on August 07, 2011 at 11:35 PM
I uses a hose and flushed water from the back to the front, after spraying it down with foamy engine cleaner. I was amazed at the amount of crap that came out that was hindering the airflow. Hope this helps.
High A/C Pressures on high side?
Draker (Eugene, OR)
19:57:28 08/06/11
Is the condensor fan working? What are the line temps? (n/m)
sandmanz32
11:31:33 08/07/11
The actual temps of the AC lines?
Draker (Eugene, OR)
12:21:19 08/07/11
R12 systems have both an expansion valve and
JMartz
07:48:25 08/08/11
Re: The actual temps of the AC lines?
sandmanz32
18:56:32 08/08/11
Fan works, high line is hot, low is cold.
Draker (Eugene, OR)
14:00:06 08/07/11
Z's that were originally equipped with R12 only had
aliaZ
11:34:04 08/07/11
The Aux fan works when I trigger it with Conzult.
Draker (Eugene, OR)
12:19:24 08/07/11
Tested the Aux Fan and it's working fine.
Draker (Eugene, OR)
13:58:39 08/07/11
Mine had a similar issue
DE944
22:07:56 08/07/11
Draker (Eugene, OR)
23:35:57 08/07/11
i cleaned the outside not the inside. -
DE944
10:02:50 08/08/11
Three things that come to mind to me...
Stadsport (PHX)
18:33:06 08/08/11
I didn't install the drier.
Draker (Eugene, OR)
10:40:47 08/09/11
I told you on 300ZX.com
aztecz34
20:50:33 08/08/11
I am well aware of the valve.
Draker (Eugene, OR)
10:31:33 08/09/11
I think I got it fixed.
Draker (Eugene, OR)
10:56:34 08/09/11
Re: I think I got it fixed.
aztecz34
23:06:22 08/09/11
